I have an empirical data in global table, and then i insert it into the process time>batch processing>cycle time>empirical distribution. but after i start the simulation, it does not represent the time of the actual data. how can i fix this?
Hi @Decardo,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
15 People are following this question.
