Iago MF avatar image
2 Likes"
Iago MF asked Jason Lightfoot commented
AGV Network - Issue Allocating Destination If Path/Body Offset
Hi!
I was creating an AGV model where, 1 meter before reaching a workstation, I need to apply a lower precision speed than the AGV's usual speed. To achieve this, I created a LoadState called "Precision." So, I used a "travel" activity with a path offset of -1m to travel in the normal load state, and then another "travel" activity to complete that meter in the precision load state. The problem is that I noticed that nothing is being allocated from the last control point before the destination. I'm not sur if this is a bug, but, how could I ensure proper allocation as if I were traveling without a path offset?
I attach an example:
23.1 Not allocating if path offset.fsm
Thanks in advace!
FlexSim 23.1.3
agvnetworkallocation
· 6
Iago Montes avatar image Iago Montes commented ·
Hi, is there any progress on this? It still happens in version 25.0.2
Jason Lightfoot avatar image Jason Lightfoot ♦♦ Iago Montes commented ·
It doesn't look like it from the issue tracker - I'll raise it to check the priority.
Julie Weller avatar image Julie Weller commented ·
Hi @Iago MF, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
Iago MF avatar image Iago MF Julie Weller commented ·
Ups, I've thanked Jason but I forgot to accept the answer. It's done now.
Thanks!
Iago MF avatar image Iago MF commented ·
This is still happening in 24.0.0 Beta
Kavika F avatar image Kavika F ♦ Iago MF commented ·
Hey @Iago MF, this issue is currently on our dev list. We don't have anyone working on this issue at the moment.
Jason Lightfoot answered Iago MF commented
Thanks for pointing this out - the lack of control area allocation looks to be a bug with any AGV offset travel (path or body), so I've sent it into the developers.
For now the only suggestion I have is to use standard travel and change the deceleration values such that the final arrival time at the destination CP is correct.
Thanks Jason!
