Hello
There is a problem in adjusting object's position, the numbers to the left of the input field are obscured, how can I solve this problem? Thanks.
Best wishes
Hello
Best wishes
Is your desktop set to any scaling value other than 100%?
Can you try closing and reopening the properties panel or even the default workspace?
Hi @Orry,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
Hello, the problem is still exist, sorry I was not post the model for you timely, cause I've been a bit busy recently
14 People are following this question.
