ahmedmedhat avatar image
ahmedmedhat asked Jeanette F commented
Turning into idle state after cleaning
In the model I attached below I managed to add a cleaning time between each item flow item and name it cleaning time, i did this through a process flow that closes and opens the processor's input port because I need the processor to be empty of any flow items during the cleaning process so I can't do it in the setup time box as the flow item acquires the processor during the setting.
However, I need after the exit of the last flow item, the processor's state to be "idle" not cleaning, as seen in the State Gantt Chart in the dashboard.
I cannot seem to make this work. any help?
Cleaning Time.fsm
FlexSim 23.0.0
setup timestatestate ganttidle statecleaning time
cleaning-time.fsm (41.2 KiB)
Hi @ahmedmedhat, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Jason Lightfoot avatar image
Jason Lightfoot answered Jason Lightfoot edited
Just put the state code into your process flow.
· 2
ahmedmedhat avatar image ahmedmedhat commented ·
the process flow tab doesn't want to open, the file seems a bit corrupted.
Can you resend it or screenshot the codes you entered?
Jason Lightfoot avatar image Jason Lightfoot ♦♦ ahmedmedhat commented ·
Re-download the model as there's no problem with the version stored on this site.
The state changes are just the standard option in the custom code activity.
The difference in the model I uploaded is that I changed the process flow to an Object Process Flow - which you define once for all the processors that need it, and add them as member instances. The each is referred to using 'current' as shown above.
