Tee Hiett avatar image
Tee Hiett asked Andrew O commented
Import scheduled time as label on a patient
In a Posting a few years ago, @Matthew Gillespie wrote:
I think the best thing to do in this case would be to add another column in Excel and duplicate the first column data in this row. That way when you import the file you get another Label column in the Date Time Source's table.
I am having trouble doing this. A little help would be greatly appreciated.
FlexSim 21.2.4
scheduled arrivalexcel importing
· 2
Tee Hiett avatar image Tee Hiett commented ·
Thanks for your help. That first process seems to work. The first patient.ArrTime shows 13:00:00.
Now, how do I compute the patient.ArrTime - patient.CreationTime in the attached model?
Andrew O avatar image Andrew O commented ·
Hi @Tee Hiett, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Felix Möhlmann answered Felix Möhlmann commented
What step are you having trouble with?
For the first solution in the linked post, you would add a string label to the source table and copy the first column over.
You can also use the second approach Matthew posted as a later comment, which is to read the time from the table view of the schedule. In addition to that reply, you can then use the "DateTime" constructor to convert the numerical value into a time string that contains the hours and minutes.
Felix Möhlmann avatar image Felix Möhlmann commented ·
To compute the difference between two times I would keep them as numerical values so you don't have to convert the strings back before doing the calculation.
You can use a variant of the second method above to assign the scheduled time from the table to a label by defining the value of the label in custom code. (The code below assumes that the model starts at midnight, so that the value in the table is equal to the model time at which the patient is scheduled. It then also adds to the time depending on the cycle count with the assumption that a daily repeat might be added later.)
Then you can just read the current time with "Model.time" and compare the two numbers directly.
If you want the values in the string format, you can convert them afterwards like you do with when reading the time in your attached model.
