Oscar C13 avatar image
1 Like"
Oscar C13 asked Felix Möhlmann commented
Name of the token
Hello, I am having troubles with obtain the name of the token created by a event triggeed source.
I suppose that the name is defined in the "Token Name" box, but I can´t refer to that name later in a decision box.
What would I have to put in the token name and what would I have to put in the decision block?
I tried with token.name, current.name, "name"...
FlexSim 22.1.3
event-triggered source
1 Like"
Felix Möhlmann answered Felix Möhlmann commented
"token.name" is the correct expression to access the name of a token. Could you share screenshots of what you assign in the Token Name field and what syntax you are using in the Decide activity?
· 4
Oscar C13 avatar image Oscar C13 commented ·
Decision:
error:
Felix Möhlmann avatar image Felix Möhlmann Oscar C13 commented ·
You are trying to assign a label value as the name. The token is being created in the event-triggered source, so I don't know where the label (and the value) should come from?
In the Decide activity you are expecting the value to either be 0 or 1. What decides which of the values should be assigned?
Oscar C13 avatar image Oscar C13 Felix Möhlmann commented ·
The event-triggeres source is waiting for a change in the variable. That variable only can value 0 or 1 and that variable is controlled by a PLC. So, I want to do different actions depending on the value.
I hope I have explained myself properly.
