I was running the experimenter to see the results of adding an additional shift. This shift was managed by its own schedule, technicians and processors - separate from the existing operations.
The results from the experimenter weren't aligned with my expectations - in fact they were somewhat nonsensical. I started observing the model in 3D run mode removing any interaction of the new shift Operators to see what was going on.
I noticed that the new shift processors had started operating, despite no assigned operators for the task. Why is this happening? I suspect that this odd behavior might be behind the results I am seeing.
Is it possible for operators to be called into other operations that their dispatcher is not assigned to?
TIA
Dustin
