Sia Sengchoon193 avatar image
Sia Sengchoon193 asked Jason Lightfoot answered
Can 1 queue have both outbound and inbound functions?
Can 1 queue achieve both inbound and outbound functions?
I've been trying different combinations,
For example, the time of a specific morning is inbound,
The afternoon and evening are outbound,
or mix, depending on the order,
And there can only be 1 item on the queue,
Does this require table or process flow?
outbound +inbound.fsm
FlexSim 21.2.1
queueinboundoutbound
Joerg Vogel avatar image
Joerg Vogel answered Joerg Vogel commented
· 2
Sia Sengchoon193 avatar image Sia Sengchoon193 commented ·
@Joerg Vogel
sorry, where should I set this up?
Is it in the queue?
Joerg Vogel avatar image Joerg Vogel Sia Sengchoon193 commented ·
If it is depending on time, you can use down and resume function of time tables. If you control input of queue then do it n On Entry or On Exit as trigger or event in Process Flow.
If you want get evaluate a cascade of several closing actions right, you are probably better of with properties stop / resume for objects.
Jason Lightfoot avatar image
You can try to use Port By Case in the Send and Pull fields such that you pull and send to/from 1 or 2 depending on the time of day. You can either put expressions in those fields to decide the time for every item, or use a label that is set on some timetabled event. When switching from one port to another you should probably open the inputs of the queue to force the pull reevaluation.
