if the passenger exceed elevator capacity, what can i add in process flow,without ussing location
Hi @Martin C10,
Why do you not want to use a Location object? It would be a fairly simple matter to use a Waiting Line in conjunction with your Elevator Bank to achieve your desired effect/result. See Waiting Line (flexsim.com) for more details.
I hope this helps! Let us know if you have further questions.
Hi @Martin C10,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
I have found a proper solution , thanks for mention me:)
14 People are following this question.
