Hi, everyone
I was wondering if it's possible to make my crane do the job as stacker reclaimer. How can i make my crane taking item from queue 1 to cluster at one time and then moving item from cluster to queue2 in another time. Thank you!
Hi, everyone
Also please note that ver 19.0.0 is not supported. Please use another version.
David
@David Chan so here how the item flow :
there is a source below the crane that supply item to each cluster at time 0, then the crane send the item from the cluster into queue 2 while waiting item arrive from source 1 to queue 1 ( in the left side of pict). After the item from source 1 arrive in queue 1, the crane will stop sending item from cluster to queue 2 for a certain time and sending item from queue 1 to each cluster for a certain time.
Not sure if this is what you are looking for
Hello @Andre T6,
I believe I have modified @David Chan's model to achieve your desired outcome. Instead of just using the 3D model logic, I have added a process flow to the model to aid with deciding which items to retrieve first. I added a priority and a destination label to each item that changes when it enters a new queue, and I just have them push to lists when they are ready to be transported to the next area. Since I set the items in Queue1 to have a higher priority than the cluster queues, those items will get pulled and transported first, which seems to be what you want. I hope this helps!
Hi @Ryan Clark,
Thanks for modified the model into a new one. This model is similar to the one I wanted to work on and the model that you provided is very helpful.
15 People are following this question.
